Hello!! I have to simulate a periodic rotation of an airfoil around the z-axis ( my problem is 2d) and calculate the instationary coefficient. The rotation is defined by a torsional time dipendent law:
alpha(t)= alpha0 + alpha^(jwt) How can I do to define a UDF that simulate the rotating wall?? I have tried to use an UDF but with no good results.... Hoping that someone could help me...is for my thesis!!! Thank you in advance |
You can refer to a UDF manual, such as you can define a DEFINE_REGID_MOTION, etc. The UDF program in that manual is very helpful.
I can't find a function called define_rigid_motion..I know about a function called DEFINE_CG_MOTION..someone can help me with this one?? Thank you
Sinusoidal Geometry | Jayadi Lukito | CFX | 7 | September 23, 2008 16:40 |
meshing in a sinusoidal channel | SATYA PRAKASH KAR | FLUENT | 0 | April 18, 2007 05:25 |
Airfoil Sinusoidal Motion - How? | Andrew | FLUENT | 1 | April 8, 2005 19:42 |
sinusoidal wall BC using a UDF | Aravind | FLUENT | 0 | November 4, 2004 13:08 |
sinusoidal boundary | Amadou Sowe | FLUENT | 0 | November 9, 2000 15:18 |
