Problem meshing with Gambit
Old   October 3, 2008, 10:00
Default Problem meshing with Gambit
Adrian
Hi guys Im working with cars and I have a problem meshing with Gambit what happend is that when I mesh the wheel of the car appear cell with high skew >0.97 because there is a wedge between the wheel and the ground and I have bad cell in that zone Can anybody help with how to solve that kind of problem? I would like to thank you to you all greetings Adrian
Old   October 3, 2008, 10:57
Default Re: Problem meshing with Gambit
doki
well that means the mesh at the region is not sufficinetly enough fine or even the strategy for meshing that area is not appropriate. you can check both reasons. but I guess is is better to simplify the geometry somehow. also, you can decompose the domain more in the bad quality region.
Old   October 3, 2008, 22:06
Default Thank you doki but...
Adrian
Thank you so much doki for help me ..I would tell you that I tryed to mesh that wedge area I mean between the wheel and floor of the car so what I did was first with a very little cell and the problem increase second I tryed to increase the cell in that zone and I realise that the bad cells > .97 decrease but the cell are big so Iīm confuse I donīt use any size function y that zone neither size function curvatura
Old   October 5, 2008, 06:12
Default Re: Thank you doki but...
SA
use triprimtive mesh topoly
Old   October 6, 2008, 02:46
Default THANK U DHOKI WHENU SAY MORE CELL/ DECOMPOSE FURTH
shashi
I am also facing similar problem. sir , i am dealing with similar problrm with complex volume where face changes from circular to semi circular and then rectagular. ^though i created faces but some faces are showing skewness > .97. Is it advisable to continue or increse number of cell. further when doing volume meshing, can we continue for skewness > .97.
what is the best way to decompose the geometry
Old   October 6, 2008, 11:57
doki
well regarding your questions, firstly I can not get the exact problem you mention. But as a general rule, finer meshes can sustain boundary integrity. But this may led to some problems, e.g. the number of mesh. I think the problem might occur when meshing an extremely narrow area; which is more experienced in complex cases. and to avoid this problem, you should either increase the near-surface meshes or simplify the geometry (if possible). there is no general rule about the decomposition of domain. that is a highly case-sensitive procedure.
Old   October 6, 2008, 12:36
Default Re: Thank you Doki again...
Adrian
Thank you Doki for help me I will try to mesh increasing tha cell in that area I will see what happend and I will tell later Thank matey Adrian
Old   October 7, 2008, 08:47
shashi
Thanks Mr Doki, but what about skewness greater than .97, can I continue or refine/decompose it.
a volume has two lateral faces , one with circular and another with rectangle. how to mesh, kindly advise
Old   October 7, 2008, 09:39
doki
refining the mesh can even worsen the situation. that is not a case to be clearly resolved! geometry complexity is an initiator for the mesh poor quality. the more zones you have, the better quality meshes you can get.
Meshing problem in gambit abhishek mukherjee FLUENT 1 July 22, 2008 05:23
Gambit meshing problem David Banks Main CFD Forum 0 July 19, 2007 12:48
3D-gambit meshing problem prem FLUENT 3 February 28, 2006 03:42
GAMBIT meshing problem George FLUENT 2 October 30, 2003 09:50
meshing problem with gambit. jx FLUENT 2 June 30, 2003 05:05
