Hydraulic diameter
Old   September 29, 2008, 09:07
Default Hydraulic diameter
OFXJ
When simulating a jet flame and due to lack of computational capacity only simulate a quarter of the 3-dimensional model, how is the hydraulic diameter defined. If the edge boundry conditions are defined as periodic are the hydraulic diameter calculated from the quarter of the circle or the whole circle?
Help would be highly appreciated!
Old   September 30, 2008, 01:56
Default Re: Hydraulic diameter
Prasad
I believe it should be calculated from the dimensions of the quarter itself. Please note that you should be specifying the flow rate through inlet only for the quarter. i.e. (Total flow rate)/4. In case you're specifying velocity it should be specified as the same.
What is hydraulic diameter and reference value? vincent FLUENT 1 October 1, 2007 10:59
Fluent : Hydraulic Diameter < 1mm ok??? jerome-gmc FLUENT 0 July 4, 2005 06:35
Hydraulic Diameter Chris FLUENT 0 June 24, 2005 19:22
hydraulic diameter David FLUENT 4 June 22, 2005 05:20
How can I change the hydraulic diameter felh FLUENT 0 January 23, 2003 08:31
