tips for runing Gambit without Exceed in Win Vista
Old   September 24, 2008, 19:38
Default tips for runing Gambit without Exceed in Win Vista
Fabio Saltara
This can be usefull because only Exceed 2008 runs in Vista. If you donīt have exceed 2008, you must install Xming with the fonts package:
1) Go to http://sourceforge.net/project/showf...roup_id=156984
2) download Xming and Xming-fonts
3) Install Xming
4) Install Xming-fonts ticking all fonts when asked
5) Click on the Gambit Icon. In the options box, add "-dev X11" after "-r 2.4.6 ". So, you must read in the options box "-r 2.4.6 -dev X11"
6)Click "run". Gambit will shortly complain that does not locate exceed, but will work after some seconds.
If you donīt install the Xming-fonts package, Gambit will start working, but as soon as you try to mesh a face or volume it will crash with a sigsegv message.
The "-dev OpenGL" options doesnīt work with Xming.
This procedure also works in Win XP 32 bits. It has worked in Vista Home 32 bits. I have not tryed it in XP 64 or Vista 64.
Old   April 20, 2009, 19:16
Default Excellent
rkz
rkz is on a distinguished road
This works very well. I have to run Xming before running gambit
rkz is offline   Reply With Quote
Old   May 8, 2009, 09:29
Mexi1983 is on a distinguished road
Could you explain better how to do this:
"Click on the Gambit Icon. In the options box, add "-dev X11" after "-r 2.4.6 ". So, you must read in the options box "-r 2.4.6 -dev X11""
What is the Gamit Icon? I don't see the options box, what can I do to see it?
Thank you.
Mexi1983 is offline   Reply With Quote
Old   January 7, 2010, 21:24
Hector Antonio Alcalde Ludeņa
hector is on a distinguished road
Originally Posted by Fabio Saltara
;153585
3) Install Xming
Hi Fabio
I make the same steps that you said, but when I try to run Gambit, it doesn't run, I wait but nothing happen.
I get the message that I forward. Please help me with that, as soon as you can.
Regards!
Hector
hector is offline   Reply With Quote
Old   March 7, 2010, 15:24
Default run Gambit without exceed
Federico
FR3DR3RIK is on a distinguished road
excellent tips thanx! Iīve tried to use xming but i had some troubles to configure screen resolution, so finally i used cygwin and works very well.
For more information visit this website:
https://engineering.purdue.edu/MECL/...n-gambit.whtml
FR3DR3RIK is offline   Reply With Quote
Old   May 20, 2010, 13:27
Jin Seok Park
aeropark is on a distinguished road
Hi Hector
I think that the Xming is not running when you start Gambit.
Xming should be running before you start Gambit.
It works well even Window 7 x64.
aeropark is offline   Reply With Quote
Old   May 20, 2010, 16:35
Jan
vinaynitrkl is on a distinguished road
my gambit version is 2.3.16.
My gambit stops working as soon as i click the run button!
vinaynitrkl is offline   Reply With Quote
Old   July 14, 2010, 17:36
DoHander is on a distinguished road
Xming works as a perfect replacement for Exceed on Windows 7 32/64 bits, but only for Gambit 2.4.6
Do
DoHander is offline   Reply With Quote
Old   January 24, 2011, 15:35
Killen Should
shields is on a distinguished road
;153585
3) Install Xming
Thanks OP, works perfect. Only new to FLuent/Gambit and my head wa wrecked with nothing coming up on the screen.
Thanks
shields is offline   Reply With Quote
Old   September 23, 2011, 14:59
Naser Imran Hossain
nihossain is on a distinguished road
;153585
3) Install Xming
Hi, I'm getting the following reply when trying to run Gambit 2.3.16 under Win 7, 64 bit
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device X11 -id default_id5664 -new ...
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/uh-nih:0
Unable to open display
Any idea how to fix it? I did all the things instructed
nihossain is offline   Reply With Quote
Exceed intallation on Vista maurizio FLUENT 6 October 30, 2008 18:03
Is there way to run Gambit on Vista without Exceed jrg FLUENT 0 September 25, 2007 01:32
EXCEED FOR VISTA shriram Main CFD Forum 6 July 27, 2007 13:47
EXCEED FOR VISTA shriram FLUENT 6 July 26, 2007 12:19
Runing Out of memory in Gambit Akin FLUENT 6 February 10, 2005 16:32
