K epsilon values
Old   September 24, 2008, 11:18
Default K epsilon values
Adrian
Hi Fluent Userīs Iīm working with cars and I would like to know what values do I have to put in inlet and outlet bondaries when fluent ask me K epsilon values thanks
Old   September 25, 2008, 09:04
Default Re: K epsilon values
Saintest
you can get the K value accoding the following equation. Tu=sqrt(2k/3)/V_far sorry I don't kown how to set the epsilon value for car!you can try the default value. it bother me for long time how to set the epsilon value and omega value for k-e and k-o model.
Old   September 25, 2008, 10:12
Default Thank Saintest
Adrian
Thank Saintest I will try and I tell you later thank you again Regars Adria
Old   September 26, 2008, 12:16
Default Re: Thank Saintest
John S
Computing values for k and epsilon is not a simple task and more often than not you will have to guess for the initial solution. You can use the equation given already to guess an initial value for k and a good initial guess for epsilon can be made using e = .9k^(3/2) / l; where l is your turbulent mixing length. The mixing length can be estimated using l = K*(1-e^(-y+/A+)*y; where K is the von Karman constant ~.41, and A+, for your case, would be 26 I believe (zero streamwise pressure gradient flow).
Modify, G_k,k and epsilon values on wall functions Javier Larrondo FLUENT 0 September 15, 2008 22:34
what values of k-epsilon? Rajil Saraswat FLUENT 0 July 16, 2003 21:32
K - Epsilon values David FLUENT 2 March 5, 2001 10:31
K- Epsilon values Dave FLUENT 0 March 4, 2001 17:49
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 13:42
