3d Gambit meshing shows out of memory
Old   September 21, 2008, 03:27
Default 3d Gambit meshing shows out of memory
tamjid
hi fellows,
3d gambit meshing shows out of memory.saya critical memory has been reached.
i have core 2 duo , 2.5 GB ram , 2 MB cache m/c.
it is a design of a complex aeroplane body ( 30 m long & 20m wide wing).
i divided the volume in as much small volumes as possible .
can gambit be run parallel as fluent. can meshing be done in fluent ,cause i can run fluent parallaly. i have considerable amount of memory in hand for parallal fluent.
please help,its urgent.
Old   September 21, 2008, 18:36
Default Re: 3d Gambit meshing shows out of memory
red lemon
mesh the parts separately then use fluent or tgrid to stitch the meshes together.
Old   September 22, 2008, 06:23
Chandra Manik
Or you can change the quality of your mesh anyway.
Old   September 27, 2008, 02:01
Thanathat
How should we do for use FLUENT to stitch the meshes ?????
In GAMBIT meshing, Out of Memory! ? Conan FLUENT 7 November 10, 2008 05:02
memory -gambit costel FLUENT 4 July 11, 2008 07:09
Gambit 3D Meshing: Error: Out of Memory Sucho FLUENT 1 May 2, 2007 08:13
our of memory in meshing BAOYU FLUENT 0 February 8, 2006 13:16
out of memory while meshing Rahul FLUENT 2 December 31, 2003 05:25
