Importing IGES files into GAMBIT and meshing
Old   September 19, 2008, 12:44
Default Importing IGES files into GAMBIT and meshing
kartik
hello
I am trying to import a simple cone with half angle 25 degrees into gambit and mesh it.
I created a cylindrical geometry around the cone and was trying to generate a mesh after subtracting the cone geometry from the surrounding cylinder.
I am getting some errors and not able to work around the problem
Any suggestions ?
regards kartik
Old   September 22, 2008, 02:09
Default Re: Importing IGES files into GAMBIT and meshing
Rishikesh
dear kartik, could u specify what type of errors u r getting? moreover r u using a licensed copy or pirated version of gambit?
regards
Rishikesh
Old   September 22, 2008, 11:57
Kartik
Hello Rishikesh ..
I am running GAMBIT on a university SUN Sparc box at GWU. So I don't have any license information on it.
At this stage I am getting a "Out of memory" error while it's doing the meshing and I have to kill the process.
Do you know if this is because there are too many mesh elements being generated with respect to memory allocated locally on the box?
Regards kartik
Old   September 23, 2008, 01:12
Rishikesh
karthik
could u please elaborate a bit more about the geometry u are meshing,so that i can tell u a rectification if possible
also specify the meshing scheme which u have used.
Regards
Rishikesh
Problem importing iges file to Gambit Tassos FLUENT 0 May 7, 2008 05:28
How to export from gambit to iges files. Lily FLUENT 1 October 2, 2007 18:52
Importing iges file Gambit error piyush FLUENT 2 April 28, 2006 09:42
how to mesh iges files with gambit 2.0 ? Lionel FLUENT 2 June 23, 2004 04:06
Problem importing IGES files into ICEM CFD Patrick Main CFD Forum 2 December 6, 2001 13:44
