September 19, 2008, 02:19 |
Heat Exchanger Efficiency
Hi All,
I'm modelling a 3D cross flow heat exchanger with a simple hex mesh less than 200,000 cells. I'm running on default convergence criteria of 3 orders of magnitude residual decay. The boundary conditions specified are for the exhaust air into HX and fresh air into HX both at a certain temp and mass flow rate, however the exhaust flow rate is double the fresh air supply flow rate. Outlets are pressure outlets. The heat exchanger efficiency I'm getting simply by ratio of two temps is about 40% higher than my experimental values which are quite accurate. I'm just using the energy equation and shell conduction, not any specific heat exchanger models. Is there any way to bridge the gap in simulation and experimental efficiencies? I assume that if I use a denser mesh and stricter convergence criteria it will simply become more efficient in CFD...? Thanks for reading this |
heat exchanger | pratap behera | FLUENT | 3 | August 10, 2010 23:56 |
heat exchanger | Nicolás | FLUENT | 0 | August 29, 2007 10:17 |
Heat Exchanger...TWO | Walid | CFX | 2 | July 11, 2005 19:04 |
Heat Exchanger | wawang | FLUENT | 0 | January 21, 2005 15:50 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
