Help for Fluent udf on parallel computing
Old   September 18, 2008, 01:52
Default Help for Fluent udf on parallel computing
KAILI
My udf is used for dynamic mesh.
In paralle,the error:
Updating mesh at time level N... done. time=0.000000 omega=1000.000036
iter continuity x-velocity y-velocity energy k omega time/iter
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytesunable to read the cmd header on the pmi context, Undefined dynamic error code.
: No such file or directory unable to read the cmd header on the pmi context,
Undefined dynamic error code. received suspend command for a pmi context that doesn't exist: unmatched id = 0
received kill command for a pmi context that doesn't exist: unmatched id = 0
job aborted: rank: node: exit code[: error message]
0: ifrc_k: -1073741819: process 0 exited without calling finalize
1: ifrc_k: -1073741819: process 1 exited without calling finalize
The Parallel FLUENT process could not be started.
This is the udf:
#include "udf.h" #include "unsteady.h" #include "stdio.h" #include "stdlib.h" /************************************************** **********/
real current_time = 0.0 ; /************************************************** **********/
DEFINE_CG_MOTION(Pitching,dt,vel,omega,time,dtime)
#if !RP_HOST
current_time = CURRENT_TIME ;
vel[0] = 0.0 ;
vel[1] = 0.0 ;
vel[2] = 0.0 ;
omega[0] = 0.0 ;
omega[1] = 0.0 ;
omega[2] = 17.453292222 ;
Message("time=%f omega=%f\n",current_time,omega[2]*180.0/3.1415926) ;
#endif /* !RP_HOST */
The code worked well in the serial process.
Do you know what happens?
Thanks!
Fluent UDF on parallel computing Andrea Fluent UDF and Scheme Programming 22 August 12, 2015 08:44
Parallel computing in Fluent 6.3 Poovanna FLUENT 2 February 18, 2011 10:17
UDF in parallel computing Shamoon FLUENT 4 May 25, 2008 15:33
parallel computing Daniel FLUENT 1 November 21, 2007 17:09
problem!! FLUENT 6.2 -SUSE parallel computing khanjaved FLUENT 1 August 15, 2005 23:00
