September 16, 2008, 03:16 |
a strange erro message
Hi, I am simulating multiphase flow in stirred tanks. I generated the model and meah in Mixsim and then switched to Fluent panel and did the settings for multiphase flow there. Everything was going smoothly if I ran the calculation in Mixsim (or switch to Fluent panel from Mixsim panel). However, a error occured when I ran the calculation in Fluent environment solely. I mean, I closed mixsim, opened Fluent, read the case&data file, and the started iteration. the error mesage is Cell_Function_Values:Unrecognized function: turbulence.
erro message while opening gambit | Emma | FLUENT | 5 | September 10, 2011 12:46 |
ACIS erro 50005 | rahul | FLUENT | 0 | July 5, 2006 15:57 |
Help?Running erro? | robert | Siemens | 1 | January 21, 2005 10:43 |
Bus erro? | Lee | Siemens | 0 | January 6, 2005 11:37 |
fluent erro | co2 | FLUENT | 0 | May 9, 2004 11:56 |
