piston-cylinder UDF
Old   September 16, 2008, 03:19
Default piston-cylinder UDF
carno
I am trying to move the piston in a 2D piston cylinder arrangement with CG_MOTION macro. Piston is moving correctly but the mesh along the cylinder is not changing and the end point of the cylinder is remaining at its original position and creating problem of mesh distortion.
1. Initial position: arrangement look like a rectangle with piston at BDC. 2. After some time the piston moves up and arrangement look like a rectangle with bottom end open and piston at some position in the open rectangle. (cylinder side lengths remain same). This is the problem and the run comes out with negative volume error.
How to resolve this problem?
Thanks
Old   September 16, 2008, 09:04
Default Re: piston-cylinder UDF
doki
I'm wonder if I've understood the problem correctly, but the thing is you have to define the piston walls as All of your bottom edge. Also, you probably should define the cylinder liner as "deforming" in fluent. the negative volume is probably because of a crevice-like portion between the piston and cylinder liner.
Old   September 17, 2008, 01:30
carno
Thanks Doki. After defining the deforming cylinder wall problem got solved.
help to simulate 4-stroke piston cylinder san Siemens 2 September 29, 2006 14:37
CFD Work on 4-stroke piston cylinder san FLUENT 0 September 20, 2006 14:27
tutorial for 3D CYLINDER-PISTON ARRANGEMENT sachin bhalerao FLUENT 0 February 28, 2006 04:05
piston/cylinder leak Elsayed M Main CFD Forum 1 September 1, 2004 12:21
Mesh for Cylinder-Piston? Serkan Cetin Main CFD Forum 3 December 4, 2002 12:44
