problem with VOF model
Old   September 15, 2008, 22:34
Default problem with VOF model
vuthuan
I have a problem in simulating of wave generation in a tank. I use 2D mesh, VOF model, inviscid fluid and used UDF to make one end as sinusoidal movement. I don't know why I can not see the wave propagate to the other end of the tank (It just propagate about 1.5m (wave length is 0.5m) then disappear) even I had extented the enough calculating time (I manually estimated group velocity, knowned-tank length). Could anybody explain me why? Thank in advance
Old   September 17, 2008, 21:45
Default Re: problem with VOF model
Davy
I think your mesh must be fine enough to capture the wave motion accurately and to avoid numerical diffusion. Especially, along the wave height the discretization cannot be too coarse.
Old   September 17, 2008, 21:47
Davy
Old   September 19, 2008, 22:42
vuthuan
Thank you, I have already refined my mesh and used 2nd-order. The result shows better.
Old   September 30, 2008, 23:58
Default 2nd problem with VOF model
vuthuan
I try to simulate free surface with wave generation but I don't know how to choose boundary condition to simulate radiation condition. I mean the wave will progress infinitely. I had tried to use flow out and pressure out but the result is not satisfied. Could anybody please to help me about this problem?
Thanks,
problem with vof model nadav wetzler FLUENT 1 February 26, 2008 03:09
Problem with DES model mehul Siemens 0 April 12, 2006 09:01
Problem with DES model mehul Phoenics 0 April 12, 2006 09:00
problem of RSM model lingo FLUENT 1 June 6, 2004 03:39
Model problem? David FLUENT 0 December 5, 2000 22:53
