September 10, 2008, 07:07 |
How can I use Porous Media and VOF together?
Hello all I'm interested in model Vacuum Infusion Process by using Fluent Software. I have to model resin flow through porous fiber (composite panel). Some problems have occurred. The most important problem is when I use the VOF option; the porous zone option from flow boundary condition almost becomes inactive. So I can't determine viscous resistance and inertial resistance. Only fluid porosity option remains active. Please guide me to implement VOF and Porous Media together. When resin reaches to fiber, heat generation occurs. Another problem is how I can use heat generation. There is only a simple option in the source Terms. I would appreciate all the help I can get and make me able to solve these problems. Thank a lot.
April 15, 2009, 07:07 |
julia davourie
hello mojtaba,
i'm new at fluent and i encountered recently the same problem : how to set porous parameters when using a VOF model. I might have found a solution : for BC of type fluid, you select mixture and activate the porous zone. Then you select your primary phase and secondary phase, where you can set the porous parameters as usual. I hope it is clear enough... and not too late ! |
Free media&porous media.Big changes in properties. | Isi | Main CFD Forum | 1 | July 14, 2008 08:18 |
porous media | mikezhang | Phoenics | 2 | September 21, 2002 22:10 |
Porous baffle and porous media | Jan | Siemens | 0 | June 8, 2002 10:23 |
Porous media | James Hampson | FLUENT | 1 | January 12, 2001 13:29 |
Porous media | Alberto | FLUENT | 4 | July 20, 2000 06:47 |
