September 10, 2008, 00:41 |
Reading case file at certain time interval
Dear Folks,
When we perform an unsteady simulation and write the results into the case & data file, is there anyway we can re-display the result (i.e. vector, contour, etc) later on at some time interval of the simulation? Appreciate your comments. |
September 11, 2008, 07:54 |
Re: Reading case file at certain time interval
Try looking into creating "Journal" files, you will have to manually write in the commands to read in each data file and copy the text to export the desired data after each read command. This sort of post-processing can be tedious.
why did my time interval set for output nouse? | ShFlow | FLOW-3D | 2 | January 11, 2009 21:25 |
Execution time problem after first write interval | sean_mcintyre | OpenFOAM Running, Solving & CFD | 3 | July 28, 2008 09:46 |
help! sth wrong while reading case | xuan | FLUENT | 1 | May 21, 2007 03:01 |
Case Reading in Fluent | Youenn | FLUENT | 2 | July 4, 2006 04:47 |
Reading a case file in Fluent | Pavan | FLUENT | 3 | March 9, 2006 03:26 |
