UDF to change Rotation Speed in a MRF simulation
Old   September 5, 2008, 10:00
Default UDF to change Rotation Speed in a MRF simulation
Mike
Does anybody know if it's possible define a UDF to change the rotation speed in a Moving Reference Frame unsteady simulation? If you have a variation in time of a variable (x-component of velocity for example) you can write the udf to give an u(t) law and than load it in the boundary-condition (velocity inlet) panel. For fluid, when you define the MRF there is NOT the menu to load the user-defined variable! How can I do?
Thank to all Bye
Old   September 5, 2008, 17:13
Default Re: UDF to change Rotation Speed in a MRF simulati
red lemon
accelerating udf for MRF is available on fluentusers.com. This has been in existence for a long time now.
Old   September 6, 2008, 03:39
Mike
Thank you red lemon.If you have it, can you post here?
Another information : is possible a similar udf also for Sliding Mesh acceleration? Thank you so much.
Old   September 27, 2011, 07:46
amini
amini_p is on a distinguished road
I need UDS that change the rotation speed in a Moving Reference Frame unsteady simulation so, have you it? i couldn't find it on fluentusers.com.
thanks a lot for your help.
amini_p is offline   Reply With Quote
Why Specify rotation speed? NTM FLUENT 2 September 12, 2008 06:39
Rotation Angle In MFR Simulation Ste_lakey CFX 2 November 8, 2005 06:22
constant rotation speed Mangnan CFX 8 May 26, 2004 22:22
How to get a constant rotation speed? Mangnan CFX 6 May 13, 2004 01:47
rotation speed in the domain jiaye gan CFX 3 April 5, 2004 09:50
