Tgrid wrapper surface
Old   September 5, 2008, 03:08
Default Tgrid wrapper surface
Sam
Tgrid works really well, far better than Gambit or Icem. However, does anyone know if the wrapper surface can be made out of quad elements eventually leading to a fully hex mesh rather than a hexcore bounded by tets? Thanks,
Sam
Old   September 5, 2008, 17:12
Default Re: Tgrid wrapper surface
red lemon
not in tgrid it cant but you could use ICEM's BFCart to generate a body fitted cut cell hex grid.
Old   September 5, 2008, 17:46
Sam
Thanks for the info, and saving me some time.
Do u know if this mesh in Icem can be imported into tgrid?
Old   September 5, 2008, 18:27
red lemon
I would assume not. tgrid cannot even read hanging node grids like hexcore or converted (tpoly'd) polyhedral grids. the wrapper is really for complex geometry where it is easier to have an automated approach to meshing rather than spending man time on face meshing so these models would be more suited to unstructured meshes. The best workaround to retain hex though is to use hexcore (Gambit and TGrid), hexacore (ICEM) or BFCart in ICEM. For proper structured grids you need to decompose and use something like Gambit or ICEM Hexa but you wouldnt be using the wrapper for this.
Old   September 8, 2008, 02:58
Sam
thank you for the info!
[Commercial meshers] Tgrid control surface for diagnostic purposes josp OpenFOAM Meshing & Mesh Conversion 0 November 20, 2008 06:36
CCM+ Surface Wrapper Export Ross Kippenbrock Siemens 2 July 29, 2008 15:27
TGrid Surface retriangulation Davide FLUENT 0 July 23, 2008 04:08
Surface Wrapper Zamir Rashid CFX 0 September 18, 2006 12:04
surface wrapper carno Siemens 2 February 10, 2005 05:34
