Problem with moving mesh
Old   September 4, 2008, 13:44
Default Problem with moving mesh
Sully
I am trying to use a moving mesh to semi-steady state flow thru an orifice at various spool positions within a valve. I have set the boundary condition of the moving wall to .00005m/s to simulate a very slow moving wall. Next I am setting the time steps to 2sec and trying to solve for 15 positions (every .1mm). When I preview the moving mesh, the actual travel is orders of magnitude higher than what it should be. I am using Fluent 6.2.16. Please Help!!!!
Old   September 5, 2008, 01:42
Default Re: Problem with moving mesh
mAx
how did you described the motion of your moving body?
Old   September 5, 2008, 05:02
doki
i think that is sth related to scaling the boundary movement
Old   September 5, 2008, 05:03
doki
i think that is sth related to scaling the boundary movement.
Old   September 5, 2008, 17:14
red lemon
is the grid scaled correctly?
Old   September 10, 2008, 17:52
Sully
The motion is described as a velocity within the boundary condition of the fluid and surface.
Old   September 10, 2008, 17:54
Sully
I have checked the scaling of the geometry of the model and everything seems to be OK.
Old   September 11, 2008, 01:38
mAx
it should be described in define/dynamic mesh/zones
Moving Mesh Problem Rashad FLUENT 0 August 28, 2006 05:31
moving mesh problem eos Siemens 4 January 27, 2006 21:42
moving mesh problem walid Siemens 6 April 1, 2005 18:31
Moving Mesh PROBLEM Arnab Siemens 10 October 30, 2004 03:10
Moving mesh problem Jan Majer Siemens 2 June 10, 2003 05:19
