memory shortage and 32/64 bit systems
Old   September 4, 2008, 11:05
Default memory shortage and 32/64 bit systems
doki
I have a PC having a core 2 quad CPU and 4 GB of RAM on a 32bit win OS. I am to model a complex case and I am usually in need of about 5~7 million meshes. As far as I have experienced, the required memory is sth about 1GB/1 million of mesh. So I have memory shortage for the run. How can I find the maximum affordable No. of mesh by the system (with either segregated or coupled solvers)? Another question is that, does just with a 64 bit win OS I can have more RAM used? if true, how can I do that. the motherboard has 4 sockets for RAM installation and I can use up to 8GB of RAM, Which generally can solve my problem. thanks a lot
Old   September 4, 2008, 23:21
Default Re: memory shortage and 32/64 bit systems
Daniel Tanner
Basic rules of thumb:
32-bit you can access ~ 1.5 Gb Ram (windows) per processor
32-bit you can access ~ 2.0 Gb Ram (linux) per processor
Theoretically you should be able to access 2^32 bytes of RAM (~4 Gb) though this is practically system limited.
For a 64-bit system you can access ~ 2^64 bytes per processor i.e. no memory problems. Good luck.
solving two systems together Ozlem Phoenics 1 September 28, 2005 13:08
birds and systems Aaron Main CFD Forum 12 July 31, 2003 13:39
Operating Systems and CFX-5 cfd guy CFX 2 March 5, 2003 18:47
Operating Systems for PC Erich CFX 1 January 9, 2002 21:30
co-ordinate systems George Siemens 2 May 29, 2001 12:07
