Burner Sketch for liquid fuel combustion
Old   September 4, 2008, 02:38
Default Burner Sketch for liquid fuel combustion
Ashwin C Punjabi
Hi Forum Users, I desperately need some burner sketch that can actually burn both liquid and gas fuel. I read a lot of literature on combustion but to start i need some kind of a sketch of a burner. If anyone can provide with the same that would be highly appreciated. Thankyou for your time Ashwin.C.Punjabi
Old   September 4, 2008, 14:45
Default Re: Burner Sketch for liquid fuel combustion
Allan Walsh
Yes, these can be quite difficult to locate. The good thing is if you just want to set up a generic case, you can look at schematics or cutaways of burners found on webpages for burner vendors. Look for Coen, Todd, or Hamworth-Peabody. These should give enough information on size, geometry, air flow path, swirl, etc.
If you need to model a specific burner, then you would likely have all the geometry info needed.
Old   September 5, 2008, 00:39
Ashwin C Punjabi
Hey Allan, Thankyou for the information. Any sketch would almost be a patent and so it would be impossible right to get. well i will look for rough schematics to work Thankyou Ashwin.C.Punjabi
Old   September 7, 2008, 13:00
manish gupta
hi! I am looking for a burner which can utilize less consumption of OIL (LDO), please let me know the details where the capacity should be atleast 50L. My contact me on 9811539029. Madan Mohan Mittal. or else please drop a mail on the above mentioned email id "manishgupta01@indiatimes.com".
Old   September 8, 2008, 00:32
Ashwin C Punjabi
Hi manish, how are you? Firstly which industry does your burner have application for. secondly there are dual fired , staged fuel burners available in plenty of models. fine tune your requirement and check out johnzink, hartworthy peabody, they are burner manufacturers. hope this helps thanks ashwin
Please help with liquid fuel combustion modelling tom FLUENT 4 October 17, 2014 22:08
liquid fuel combustion camby CFX 0 April 26, 2007 22:32
Help! Warnings on liquid fuel combustion Julie Siemens 0 August 31, 2004 11:58
combustion chamber for liquid fuel Kirill CFX 1 November 18, 2002 11:07
Liquid fuel combustion Yong-Ju Hong FLUENT 3 May 17, 2000 05:27
