Defining Rotor Zone
Old   September 3, 2008, 14:22
Default Defining Rotor Zone
NTM
Hello
When defining a rotor zone does the rotor zone need to be a seperate volume?
I have a cubic domain in which I want to model a rotating cylinder. Do I need to make a domain then subtract the cylinder shape from it to be able to have a rotor zone (cylinder) as a seperate volume inside?
Thanks
Old   September 4, 2008, 03:03
Default Re: Defining Rotor Zone
mAx
yes you have to isolate your rotor zone (volume) not with substracting, but with spliting. The 2 volumes (stator - rotor) shoudn't be connected if your work with moving mesh.
dynamic mesh without defining deforming zone erkan gunaydinoglu FLUENT 0 November 30, 2008 10:03
Rotor Zone in Gambit emre FLUENT 2 July 14, 2008 02:03
Defining a zone CFDNewbie FLUENT 3 July 18, 2007 17:31
Create an UDF function for defining a zone ... CFDNewbie FLUENT 0 July 18, 2007 15:19
defining interface zone more than once Tomas FLUENT 2 November 26, 2004 07:05
