FLUENT bug in cartesian-cylind velocity conversion
Old   September 3, 2008, 11:52
Default FLUENT bug in cartesian-cylind velocity conversion
Knut
in my calculations, Fluent does not seem the to get the conversion between cartesian velocity components Vx, Vy, Vz and cylindrical velocity components Radial-Velocity, Tangential-Velocity, Axial-Velocity right. I am wondering if this is a SERIOUS bug. I am simulating a turbine stage with a mixing plane in FLUENT6.3. When I produce a contour plot of Vx on an axial plane and I show 2 periodic repeats, Vx is not continuous at the periodic boundary between the 2 repeats, it has a step. If I plot the Axial-Velocity instead the step does not occur. Funny thing is Axial-Velocity and Vx must be identical by definition. Anyone has seen this before?
Problem is that Fluent *.dat file contains only cartesian velocities. If I want to load into another software for post processing I will not be able to get the right solution.
Thanks
Cartesian to cylindrical velocity field conversion francois OpenFOAM Post-Processing 11 November 30, 2017 06:52
How to treat the source term in the 1d cylind.? jinwon Main CFD Forum 0 June 4, 2007 14:15
conversion of velocity derivatives Manoj Main CFD Forum 2 January 7, 2006 05:18
Conversion of cell velocity derivatives Manoj FLUENT 0 November 30, 2005 12:08
conversion of geo file from CFX-4 to fluent Min-Hua Wang FLUENT 2 January 26, 2000 18:01
