help:uds source added to boundary cells
Old   September 3, 2008, 10:52
Default help:uds source added to boundary cells
FredPacheo
Dear all:
I got a problem with the uds profile:
The boundary cells are registered from adapt list and then separated from grid list. Cells adjacented to the boundary could be got after that named fluid-1.
Here is the question: uds source terms can not be added to the fluid-1 cells while those could be added to the fluid cells. I don't know why, Does anyone can help me?
Old   September 4, 2008, 00:43
Default Re: help:uds source added to boundary cells
seemi
Dear;
I adopted the same method to apply the UDS source on the "cells adjacent to the boundary" but I did not get any problem while putting the constant source term.
Now, is "fluid-1" cells zone are the cells adjacent to boundary?
Regards
Old   September 4, 2008, 06:17
FredPacheo
to seemi:
Thank you for your reply. I separate the cells from the velocity inlet boundary. At first, I choose "adapt->boundary(inlet, named by myself)->mark". Then I choose"grid->separate->cells->separate". Finally I get the zone "fluid-1". But I can't hook my uds source term to the zone even there is no options from the list.
Could you please give me some details of your application? If it is convenient for you, we can communicate with by email: fredzj@gmail.com regards!
Old   September 4, 2008, 23:17
seemi
Dear;
Instead of doing "adapt->boundary (inlet, named by myself)->mark", go for ""adapt->region->----". And in "Region Adaptation panel" set the coordinates of the neighboring cells to your boundary.
Remember, source term (kg/m^3-s) can be applied on the zone instead of boundary.
I hope, after trying this, you can solve your problem.
About my work, I will email you.
Regards
Old   September 4, 2008, 23:37
FredPacheo
Dear seemiļ¼š
I will try out your method.
Thank you so much!
Regards!
Old   September 5, 2008, 06:45
FredPacheo
To seemi:
I tried out your method. Fortuatelly I managed to get a cell zone"fluid-8" which can be hooked the uds profile. But when I processed another boundary by the same way, I got a cell zone"fluid:023" which can't be hooked my uds profile.
I found the difference between the two zones that one is "minus" and the other is "colon".
Am I wrong again?
identifying boundary cells alexa FLUENT 0 October 29, 2007 13:39
How to deal with new added cells chen_jun OpenFOAM Running, Solving & CFD 3 October 7, 2005 05:24
Boundary cells hemph OpenFOAM Running, Solving & CFD 0 April 21, 2005 06:22
boundary cells Ale FLUENT 2 September 4, 2003 11:31
UDF to apply source to a group of cells Hiranya Nath FLUENT 4 March 15, 2002 06:01
