【Help】"Error: Update_Time_Level: invalid data"
Old   September 1, 2008, 21:49
Default 【Help】"Error: Update_Time_Level: invalid data"
Chen
my script file:
file/rcd cyl-pitched-blade.cas.gz /solve/set/time-step 0.1 /solve/dual-time-iterate 100 20 /file/wcd cyl-pitched-blade.dat parallel/timer/usage exit yes
result:
Primitive Error at Node 0: Update_Time_Level: invalid data
Primitive Error at Node 2: Update_Time_Level: invalid data
Primitive Error at Node 4: Update_Time_Level: invalid data
Primitive Error at Node 3: Update_Time_Level: invalid data
Primitive Error at Node 1: Update_Time_Level: invalid data
Primitive Error at Node 5: Update_Time_Level: invalid data
Primitive Error at Node 7: Update_Time_Level: invalid data
Primitive Error at Node 6: Update_Time_Level: invalid data
Error: Update_Time_Level: invalid data Error Object: #f /solve/dual-time-iterate 10 100
Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed.
> Halting due to end of file on input.
could anyone give some advices on that ? what 's wrong with my setting? Thanks a lot
Old   November 10, 2012, 14:53
Default Update_Time_Level: invalid data
Jenny
Jenny_W is on a distinguished road
Hi Chen,
I am having the same problem. My simulation is ok with RANS but when I switch to LES, FLUENT reports this error:
If you have fixed your problem, could you give me some suggestions, please? I really do not know what is wrong. Thank you very much.
Jenny
Jenny_W is offline   Reply With Quote
Old   August 24, 2014, 08:51
Mahesh J Rao
mahesh.j90 is on a distinguished road
Nothing is wrong on your side.
Use
"/solve/iterate 1" and then
"/solve/dual-time-iterate 100 20"
They say this is some kind of strange error that comes when you use it in command line mode (with -g option)
Source:http://stone-circle.blogspot.in/2010...fluent-in.html
mahesh.j90 is offline   Reply With Quote
invalid command error ahmet FLUENT 2 April 24, 2021 12:17
Error: Floating point error: invalid number fpingqian FLUENT 4 February 8, 2012 02:20
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 11:00
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 19:11
invalid data range for argument? pete CFX 2 April 10, 2003 11:04
