Availability of previous time level values in UDF |
September 1, 2008, 09:17 |
Hi there, I am simulating unsteady 3-D flow with heat and mass transfer; treating air as an incompressible ideal gas mixture (02 + C02 + h20 + N2).
I would like to know whether the previous time level values " C_T_M1,...." are available for use inside the UDF. I do not solve for any UDS in my setup currently. The reason for my confusion is the statement in the UDF manual: "Note that data from C_T_M1 is available only if user-defined scalars are defined. It can also be used with adaptive time stepping" So if I am solving for species transport without using UDS are C_T_M1 and the corresponding time level values available ?. Would greatly appreciate if you could clear my doubt, that way i can structure my UDF accordingly. Thanks Ranga Sudarsan |
UDF and previous time step macros | Aleex | FLUENT | 2 | January 23, 2011 09:39 |
Restarting from the previous time step | Parsa Zamankhan | FLUENT | 2 | November 28, 2008 12:21 |
problem in UDF for Accesing previous Time | Amir | FLUENT | 0 | April 16, 2008 02:00 |
Previous time macro in UDF | Paolo Lampitella | FLUENT | 0 | March 4, 2008 12:35 |
previous time step macros | Bryan | FLUENT | 0 | January 12, 2006 15:02 |
