drag coefficient of cylinder
Old   August 26, 2008, 06:12
Default drag coefficient of cylinder
Libellen
hello friends
i want to get the drag coefficient of cylinder-2D.
my boundary conditions are velocity_inlet, pressure_outlet, side-wall and wall-cylinder. i use laminar model because Re Number is 500. i checked my REFERENCE VALUES yet.
but my calculation is wrong compare with experimets data.
please teach me what should i check the anything else.
thank you for your help.
Old   August 27, 2008, 10:18
Default Re: drag coefficient of cylinder
joh
i am not sure if you can use pressure outlet with velocity inlt. try changing it to out flow.
Old   August 27, 2008, 13:25
Libellen
Hi joh, thanks for your advise. but i have already tried it.so have i made a mistake fundamentally?
as for Cd graph, it form fluctuation, isn't it?
thanks a lot
Old   August 28, 2008, 13:12
joh
what do ya mean by fluctuation. if you a taking results at given conditions, all you should get is a number.
what is the dimension of the cylinder and what is the distance of your first cell from cylinder.
Old   August 28, 2008, 13:19
Fabio Saltara
The flow around a cylinder at Re=500 is unsteady and three dimensional. I am not sure if a 2D steady simulation can accurately calculate the CD.
Old   August 28, 2008, 13:21
joh
but consider a cylinder between two walls in ideal fluid (inviscid). still 3D flow? i dont know
Old   August 29, 2008, 04:30
Libellen
im doing a 2D simulation and set a cylinder by making circular hole in a rectangle. so i get the Cd with solve>monitors>force>drag.
i show my setup details.
i used laminar model cylinders diameter is 0.1m. a rectangle area 1*2 m^2 velocity_inlet v=0.0734m/s. material is air(dencity is constant). time step size is 0.0005
i set Unsteady Formulation>second order Implicit Gradient option >Green-Gauss Node Based Residual monitors>Absolute Criteria is 1e^-6 Residual monitors>Relative Criteria is 0.001
i did not use adapt and surface tool.
i set the Boundary layer which first row from cylinder is 0.001 in GAMBIT. Is this correct?
thanks for your help
Old   August 29, 2008, 06:32
joh
i had a problem lately with my 2d results. and it turned out that the distance of my first cell was too little. increase the distance of the first cell to 0.2 mm and see if it works. i think it should.
Old   August 29, 2008, 11:43
Jason B
Did you check your y+ values and compare those to the expected values for the turbulence model you selected?
Thanks, Jason
Old   August 29, 2008, 14:37
Will
Are you sure your reference values are set properly?
Old   August 29, 2008, 22:56
  #11
Libellen
thanks your response i used cylinders diameter 0.1(m). A rectangle area 1*2(m^2). velocity_inlet v=0.0734(m/s).
so i show my REFERENCE VALUES.
area is 0.1 m^2. depth is 1m. Length is 0.1m. velocity is 0.0734m/s. Pressure is 0 Pa. Density and Viscocity are default of air.
Is this correct?
and the distance of the first cell from cylinder is 0.1mm in my simulation. as for y+, i used laminer model. is it possible to check the y+ in laminer model simulation?
my calculation is wrong. please help me
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 04:26
Drag Coefficient Verification around Cylinder MFerris CFX 44 May 11, 2015 19:27
drag coefficient of cylinder using fluent john lynam Main CFD Forum 2 February 15, 2010 10:16
Drag coefficient of cylinder chenzhi FLUENT 1 December 2, 2008 12:23
Drag Coefficient(Cd) of circular cylinder Ram FLUENT 2 June 4, 2000 15:32
