HELP! How to make UDF for the adsorption isotherm? |
August 25, 2008, 11:07 |
Dear Fluent experts,
I am now trying to simulate the adsoption process in a chromatographic column using adsortion isotherm such as Langmuir isotherm (simple case) but I fail. In fact, I dont know how to make an UDF for the source term of the species on the fluid and stationary phases. Can any one give me suggestions? Thank you so much in advance. Thanh |
August 25, 2008, 11:28 |
Re: HELP! How to make UDF for the adsorption isoth
its depens to equation which you use,you have a diffusion term and a source term.
September 3, 2008, 12:40 |
Dear Belhadef,
Thank you for your suggestion. In my model I used a source term of species conservation equation. The source term here is the changes of species concentration on the catalyst. However now I have another problem that is I dont know how to set the axis and radial dispersed coefficients of the species (or the fluid phase) to the porous media. Can you give me some idea? Thank you so much in advance! Thanh |
December 10, 2009, 12:56 |
Same Here
Michael McMaster
Rep Power: 17 |
Thanh i am trying to do the same thing, simulate adsorption of water onto silica, i think i have to use user defined scalars or user defined functions but i dont know where to start, can anyone help?
adsorption of moisture | prasanth | FLUENT | 11 | January 11, 2019 02:40 |
Help! Adsorption problem? | Thanh | FLUENT | 1 | November 14, 2009 12:46 |
eqution of adsorption | karim | FLUENT | 1 | March 1, 2006 12:58 |
Gas adsorption into liquid..HOW?? | Ivan | FLUENT | 0 | July 3, 2003 02:38 |
Buy commercial cfd software for adsorption | li yong | Main CFD Forum | 0 | March 19, 2001 22:27 |
