pressure drop: radiator or porous jump
Old   August 19, 2008, 15:37
Default pressure drop: radiator or porous jump
luigi
I'm modeling lots of small channels connected at the ends by common volumes. For my purposes I don't need the behavior in the individual channels, just the overall flow area. So I combined them into one pipe with the correct flow area. But i want to account for the pressure drop that the fluid would experience through the little channels. How would I do this?
So far I've split my pipe into axial section and I plan on applying either a porous jump or radiator boundary condition at the interfaces of these axial sections. Are there any tips on what values i would use for the coefficients? If I've found that the pressure drop reduces by a factor of 4 for the big pipe, how could I use that for the coefficients?
Or could I use the radiator boundary condition, and for the heat transfer inputs just insert "0" in all the inputs? would that work, because the pressure part seems easier since it is just a factor?
thanks a lot
Porous jump & Porous zone - help needed Witsarut Jintaworn FLUENT 3 June 14, 2010 23:37
porous jump again Dany Rincon FLUENT 1 March 30, 2007 13:15
porous jump boundary jump thread not handled hari FLUENT 0 March 4, 2006 03:24
Porous media pressure drop coefficient Prabodh V.K. Siemens 5 February 3, 2004 04:53
pressure drop in porous media Dongying Qian FLUENT 4 January 2, 2004 15:38
