August 19, 2008, 14:11 |
Need help with a compressible flow problem
Hello Everyone,
I need to model flow / temperature / pressure in a long, sealed off (closed from everywhere), air-containing cylinder. There is a propeller fixed inside the cylinder, which stirs up the air to subsonic (but close to 330 m/s) speeds. Pressure and temperature effects are important, and the flow is modeled as compressible. The system was meshed in GAMBIT; mesh quality is high ( << 0.7 skewness). In FLUENT, I tried both Segregated and Coupled solvers in implicit formulation. Enabled Energy equation and then tried Viscous --> Spalart-Allmaras (standard) with default values and vorticity-based production OR Viscous --> k-epsilon (standard) with standard wall functions both times viscous heating was enabled. To produce compressibility, the fluid was modeled with ideal-gas law. Problems start when I have to set operating pressure. I am unsure how to define it in a closed, turbulent system. Trying to set it to zero brings many problems - the solution is unsteady (or diverges), even though I tried decreasing the Courant number to 1 as well as decreasing all the URFs and choosing 'First order upwind' in all options. My limits are quite reasonable too. If I set the operating pressure to 1atm, the solution converges with solution parameters at their default values and 'second order upwind' enabled. That's OK, but I want to be sure in my results... and the 1atm operating pressure makes me uncomfortable. Besides, most residuals converge to below 1e-3, but keep oscillating (for many, many cycles) between 1.5e-3 and say, 9e-4. Please let me know what do you think; I really appreciate your help. |
Problem with compressible flow in Star CD 3.26 | suresh | Siemens | 0 | February 17, 2009 02:02 |
convergence problem with compressible flow | S.B.J. | Siemens | 2 | February 2, 2009 05:05 |
Convergence problem with compressible flow | S.B.J. | Siemens | 2 | January 7, 2009 04:29 |
Convergence problem for compressible flow | Saad | Main CFD Forum | 2 | June 5, 2005 16:24 |
Compressible flow problem | Lewis | FLUENT | 2 | July 11, 2004 08:29 |
