how to solve steady flow in VOF model
Old   August 19, 2008, 03:17
Default how to solve steady flow in VOF model
raju
i want to solve steady flow in vof model but by default it takes unsteady...then what should i do...please help thanks.
Old   August 19, 2008, 03:46
Default Re: how to solve steady flow in VOF model
fadhil
90% cases of multiphase model is unsteady. VOF model is run only in unsteady state--because it involves tracking of the interface with every timestep.
Old   August 20, 2008, 09:01
Ravi Shankar
The methodology for VOF model is based on Density solver, which is by varying densities in the Voids of the pressure field.
The strategy is to solve the Transport equation with input volume fraction as variable.
Steady state solution should work in FLUENT, this infact consumes time triple the Non VOF model. Because the solution is obtained for every 20 iterations as default to reach convergence. And Re-constructs the geometry near surface of two phases.
Good luck.
Old   August 20, 2008, 09:59
raju
thanks for help so what inputs i have to give while solving steady state problem..
Old   August 20, 2008, 16:43
baker
that depend in what variables you want to predict and the type of your problem.I want to correct point mentioned in Ravi post the VOF model based on the pressure solver not density based and it depend mainly in the segregated solver cause the coupled solver not allowed with it (see the limitation of VOF model in the user guide).
how to solve a steady problem explicitly meda Main CFD Forum 6 September 25, 2008 07:53
plz help ,urgent ,vof model steady state Garima Chaudhary FLUENT 0 May 25, 2007 06:49
Free Surface Model for Steady State Flow Fred Main CFD Forum 2 February 3, 2006 00:08
how to solve steady-transient mixed problem? touchstone Siemens 0 September 12, 2005 11:08
HOL model with steady Clark Phoenics 2 June 17, 2005 15:32
