unsteady flow convergence issue
Old   August 17, 2008, 22:57
Default unsteady flow convergence issue
Jason
hey,
i'm running a viscous flow past a cylinder and i have altered the mesh slightly to make it more refined and i'm running the same simulation and the problem does not converge. However the previous mesh did converge, does anyone have any advice on how to fix this problem, and is there a limit to the amount of iterations per time step that i can use.
Old   August 19, 2008, 02:41
Default Re: unsteady flow convergence issue
wanghuiru
maybe you should increase your iteraion steps.your question just a fluid flow ?
Old   August 20, 2008, 09:11
Ravi Shankar
Check the following: --------------------------- 1. Have you used polar and high density mesh near wall of an immersed cylinder? 2. how did you refine the mesh? Did you use Gambit tool or did you break the cell volumes using Fluent utility? 3. You may didnt save the simulation files xxx.CAS and xxx.DAT to reuse the simulation. Case file holds all the input data and problem setup. Data file stores the results after the simulation. Find the difference. 4. For Time steps, follow Courant Number definition, from www.wikipedia.org. 5. Courant number is something to regulate the flowrate and smooth solution convergence. One can notice this in Animations.
Good luck.
convergence issue in LES Deb FLUENT 0 March 11, 2009 06:43
convergence issue Rohit Kumar Batra CFX 1 March 27, 2008 18:43
convergence issue carno FLUENT 0 February 13, 2008 04:13
Convergence issue Omer CFX 2 March 7, 2007 11:37
Convergence issue Jake FLUENT 3 June 30, 2005 05:12
