August 13, 2008, 23:55 |
increasing drag coefficient
hi, i'm modelling turbulent flow past a cylinder and when calculating the drag coefficient it just keeps increasing in value and doesn't level off, even thou the solution converges every time step
August 14, 2008, 01:52 |
Re: increasing drag coefficient
At the inlet you have to impose the proper values for the Turbulence parameters.Calculate the Turbulent kinetic for the given inlet boundary condition and Impose the same. And dissipation rate should be imposed as zero at the inlet.
This gives a better CFD prediction for Drag.This has given drag values close to theoritical values for ship hull hydrodynamics. |
August 14, 2008, 22:18 |
Do you mean for k-e viscous model i input my calculated value for turbulence kinetic energy under TKE and 0 for TDR. Do you calculate the TKE value using the equation k = 1.5*(UI)^2? It would be great if you could clarify this for me.
Thanks |
August 20, 2008, 09:25 |
Always for External flows, make sure to check this.
1. Reference values for Drag component. 2. Boundary conditions - Neumann, Dirichlet and Mixed. 3. Inlet - velocity, Outlet - pressure, Walls - Zero wall shear. Best Regards. |
Fluent Good Lift coefficient BAD drag coefficient | Rif | Main CFD Forum | 4 | March 9, 2010 11:52 |
coefficient of drag(Cd) | haris | FLUENT | 8 | January 11, 2008 00:25 |
DPM drag coefficient | Spielkind | FLUENT | 1 | August 12, 2007 13:27 |
drag coefficient | puneshwar verma | FLUENT | 2 | February 28, 2007 01:04 |
Drag coefficient | HP | FLUENT | 0 | September 1, 2005 07:37 |
