radiation transfer between solid and fluid zone
Old   August 13, 2008, 13:45
Default radiation transfer between solid and fluid zone
shyang
Dear all,
I'm modeling a radiation problem by using DO model. I have a fluid(air) zone in adjacent to a solid(silicon) zone. I select to couple two walls between them, and I also select "participate in radiation" for solid zone. (1) So how is the energy transferred between these two zones? (2) since i only want to model radiation, not the heat conduction, I choose the set the thermal conductivity of air to a very small number so as to only allow the radiation transfer. I also set a very small thermal conductivity of solid substrate so there're no heat transfer inside it. When I've done the simulation, I found in the contour results that the "incident radiation" uniformity is different from the "temperature". Do you have any idea how this happens?
Regards Thomas
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
heat transfer between solid and fluid Devy FLUENT 4 June 4, 2010 01:28
rotating solid zone with heat transfer Sasha FLUENT 1 March 24, 2009 17:55
Fluid-Solid Heat Transfer Charles Pringle CFX 6 March 4, 2007 17:16
solid fluid iteration plus radiation harish Main CFD Forum 1 January 30, 2006 05:28
