Outlet Boundary Condition ?
Old   August 12, 2008, 16:26
Default Outlet Boundary Condition ?
Maria
I am modeling jet mixing in a tank and need help choosing an appropriate outlet boundary condition. The jet will be modeled using a constant velocity inlet and I need to define an outlet condition (ideally just a mass flow outlet) which is needed to keep the volume of fluid in the tank constant. Any suggestions will be appriciated.
Old   August 12, 2008, 17:08
Default Re: Outlet Boundary Condition ?
Bryan
If you use a pressure-outlet then you will see a check box where you can turn on a target mass flow rate. Be careful using the velocity-inlet BC on this problem. I don't know your exact problem but it seems like a mass-flow-inlet might be better. GOOD LUCK
Old   August 14, 2008, 02:33
Smith_K
If the flow is incompressible then Velocity inlet and mass flow inlet are identical. Velocity inlet and Pressure Outlet BC's should be sufficient. Regards,
Old   August 20, 2008, 09:30
Ravi Shankar
The flammable fluid jetting out of a container needs the pressure difference and stochiometric fuel constants as input or as source terms.
So use the Pressure outlet boundary, mass flow rate also should govern actually.
Go through the tutorials on Combustion problem using Chemical reaction rates.
outlet boundary condition Nina Schiepel CFX 2 July 12, 2008 16:27
outlet boundary condition Arman FLUENT 2 September 22, 2007 14:08
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
Outlet Boundary Condition Tang Kuei FLUENT 1 May 22, 2006 18:18
outlet boundary condition neil CFX 1 June 17, 2002 01:57
