low drag coefficient
Old   August 8, 2008, 01:42
Default low drag coefficient
Jason
i am running a simulation of turbulent flow past a stationary cylinder and the calculated drag forces are lower than the expected values. Does anyone know some common reasons for this to occur?
cheers
Old   August 8, 2008, 03:12
Default Re: low drag coefficient
nag
have u given the reference values proper and ve u selected all the surface for drag calculation? Which is the package u r usin?which turbulence modelr u usin?
Old   August 10, 2008, 22:37
Jason
i am using a k-epsilon turbulence model and i have set the reference value, these are set from the inlet is that the correct approach? Unsure on what you meant by seleced all the surface for drag calculation as i am using a Re of 10000 surface roughness doesn't have any effect?
Cheers
Old   August 14, 2008, 01:53
Rudresh
At the inlet you have to impose the proper values for the Turbulence parameters.Calculate the Turbulent kinetic for the given inlet boundary condition and Impose the same. And dissipation rate should be imposed as zero at the inlet.
This gives a better CFD prediction for Drag.This has given drag values close to theoritical values for ship hull hydrodynamics.
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 11:52
drag coefficient puneshwar verma FLUENT 2 February 28, 2007 01:04
drag coefficient valentina FLUENT 2 January 23, 2007 14:16
coefficient of drag C.Mohan FLUENT 1 January 8, 2007 14:00
about the drag coefficient maximus Main CFD Forum 7 April 18, 2005 20:00
