August 4, 2008, 01:39 |
Turbulence Intensity
Hey, i'm modelling a turbulent flow past a circular cylinder and am unsure on what to set the turbulence intensity at the Re number i am using for the flow is 10,000. Can someone please help?
Cheers. |
August 4, 2008, 02:34 |
Re: Turbulence Intensity
normally u can set it to around 4%.any freestream turbulence decays rapidly and doesnt affect the solution much
August 4, 2008, 03:29 |
Turbulence Intesity = 0.16 x Re**(-1/8)
August 5, 2008, 02:02 |
Cheers thanks for that.
Btw do you also know what i should set my turbulence viscosity ratio as, or should i just leave it as the default value of 10. |
August 5, 2008, 15:22 |
but in case you are using multiphase flow with different reynolds number, you should get the mean Reynolds???
Turbulence Intensity | John | FLUENT | 2 | September 11, 2005 10:15 |
How to put turbulence intensity in CFD | Donghun | Main CFD Forum | 0 | October 7, 2004 21:41 |
turbulence intensity | co2 | FLUENT | 2 | December 27, 2003 19:41 |
Turbulence Intensity | Tom | FLUENT | 4 | November 14, 2003 10:53 |
turbulence intensity | l.g.patil | FLUENT | 0 | February 8, 2002 13:18 |
