August 3, 2008, 16:16 |
Parallel Processing in Quad Core Computer
Hello CFD masters,
I am using FLUENT on my Quad Core Dell workstation, it is a Windows XP system. And I have tried to use the parellel processing with the normal command for the cluster, i.e. fluent 3d -t2. But seems it only uses 25% of the CPU resources, and it doesn't speed up the calculation either. Anybody has a clue how to make it faster with a quad core computer? Many thanks, |
August 4, 2008, 14:13 |
Re: Parallel Processing in Quad Core Computer
i use ./fluent 3d -t4 -pnet and it works fine, but first you have to see if you have mpi running on your pc...
August 5, 2008, 09:35 |
Many thanks,
Core usage on CFX parallel processing | alterego | CFX | 6 | December 21, 2011 06:45 |
Parallel computing quad core | Prad | Main CFD Forum | 13 | February 9, 2009 15:28 |
Parallel processing in quad core | Renato Pacheco | FLUENT | 1 | June 4, 2008 13:06 |
Questions about CPU's: quad core, dual core, etc. | Tim | FLUENT | 0 | February 26, 2007 15:02 |
FEDORA CORE and PARALLEL processing | Tuks | CFX | 2 | August 20, 2005 12:05 |
