volume or shell for moving/dynamic mesh?
Old   July 23, 2008, 09:28
Default volume or shell for moving/dynamic mesh?
naomi
I just want to ask a question. if we want to apply moving mesh to an object, such as rotating a sphere. The sphere must be a volume (meshed cells) or can it be a shell (surface mesh)?
I am asking because my object is very complex and it is very difficult to generate the volume mesh. All this time I substract the outer domain with the object and use the object's surface mesh to mesh the rest of the domain.
Thanks
Old   July 23, 2008, 10:04
Default Re: volume or shell for moving/dynamic mesh?
mAx
if your sphere contains only solid (and if you aren't interested with conduction within the solid), you can forget the motion of the sphere. Check the tutorial of dynamic mesh, it's about a check valve with a sphere (2d-axi) fluent_help/help/html/tg/node181.htm
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
Negative Volume & Dynamic Mesh Arianna FLUENT 2 December 3, 2007 11:00
Moving Dynamic Mesh in Fluent 6.2 R.M.Bharath Somayaji FLUENT 0 January 9, 2006 21:36
Moving(dynamic) mesh in Fluent yonghyun FLUENT 1 January 25, 2005 15:50
moving solid in dynamic mesh James FLUENT 1 October 4, 2002 08:22
