URGENT - DPM Macro for custom bc
Old   July 20, 2008, 19:00
Default URGENT - DPM Macro for custom bc
cfd-user
Hello
I am trying to define a DPM BC for my DPM model such that
--> If a particle interacts with wall then use reflect bc
and if number if such reflects is more than 5 remove the particle from domain (i.e. escape)
I need following macros to execute this
a) Macro to extract number of wall/particle interaction
b) Macro to abort a particle
Can anyone tell me is this is possible if so how?
This is immediate requirement and I would appreciate any help in this
Thank you
Sandilya
Old   July 21, 2008, 12:20
Default Re: URGENT - DPM Macro for custom bc
user
hi, what is the reason of escape ? do you want to have a physical escape, or you want to have a counter which counts for 5 particles and then restart the counter ? one query here from me since you use DPM: does your particle have both linear and angular velocity ? if yes, how do you calculate angular velocity ?
best wishes.
Old   July 21, 2008, 12:26
cfd-user
Hi
I am using DPM model in 2D axisymmetric domain
I want to use a BC such that if a particle collides more than 5 times with wall I want to abort the calculation of that particle and remove it completely from the domain
URGENT custom property for UDF Sandilya Garimella FLUENT 0 May 19, 2008 13:35
load sheme macro (Solv Execute Command macro) manu FLUENT 2 March 13, 2008 02:00
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 05:18
need paper very urgent humanity,very urgent,urgent mohamed FLUENT 0 August 9, 2006 12:40
Call a macro from a macro Flav Siemens 2 July 1, 2004 06:42
