question on generating sliding mesh in Gambit
Old   July 17, 2008, 22:51
Default question on generating sliding mesh in Gambit
multiphase-flow
I want to learn sliding mesh. For a simple example, I created a cylinder, volume 1 in Gambit, then I created impeller (rushton blades) inside of the cylinder. After I created the second cylinder, volume 2 which is inside of volume 1 and rushton blades are inside of volume 2. I splitted volume 1 with volume 2 (in this way, I can set faces of volume 2 as interior). I know that is the way for MRF. But for using sliding mesh, what should I do next? Should I create a third cylinder, volume 3 the same size as volume 2 or smaller than volume 2. What is the relationship between volume 3 and volume 1, 2. I tried splitting, but it does not work. Can anyone help me? Thank you in advance.
Old   July 18, 2008, 01:33
Default Re: question on generating sliding mesh in Gambit
mAx
forget the third volume. deconnect volume 2 and volume 1. you should have 2 stacked faces between the 2 volumes. then set the 2 faces as interface.
Old   July 18, 2008, 14:05
umesh javiya
hi.... you may need to follow following steps. 1) created two separate mesh for volume-1 and volume-2..
--for this step delete one volume in Gambit and export second volume mesh but dont save gambit *.dbs file and then load again gambit file *.dbs delete second volume and export first volume...and you will have two mesh files. 2) merge two meshes in TGRID (package from fluent..you should find same directory as in fluent otherwise follow step 3).. ---for this step read both *.msh files in tgrid by file>read-mesh and select both mesh ....then just just write mesh again...by file write mesh..give third file name...this mesh is ready for sliding mesh..... read in fluent and do your simulations...
3) read first mesh in fluent....and then append second mesh file....by Grid>zone>append case file and select second mesh file...and do setup you boundary conditions as in sliding mesh tutorial......
Best of luck....
Old   July 21, 2008, 12:17
jesse
the grid is the same, with different zones on the either side of the interface;
boundary condition/ solid/moving mesh
define/grid/interface (here identify which one is the interface for which zone)
Old   February 21, 2012, 01:36
Default sliding mesh , plz help
sheikh nasir is on a distinguished road
hi i am using sliding mesh technique in my case i.e train moving in tunnel . i am not able to work it out . can any body help me. my email is sheikhnasir39@gmail.com
sheikh nasir is offline   Reply With Quote
Sliding mesh setup for a mixing tank in Gambit nycera FLUENT 13 October 11, 2016 15:39
sliding mesh using Gambit vivek FLUENT 2 February 21, 2012 06:44
Gambit - sliding mesh preparation mistake Maciej FLUENT 5 February 21, 2012 06:32
sliding mesh with gambit Gopal Kasat FLUENT 1 February 15, 2010 13:32
sliding mesh interface question Kyle FLUENT 0 February 26, 2008 10:36
