Maximum no. of mesh fixed at 100k in Gambit?
Old   July 15, 2008, 22:50
Default Maximum no. of mesh fixed at 100k in Gambit?
Peter
Whenever I try to mesh a large mesh, Gambit always end the mesh at 100,000 cells although the meshing is incomplete. How do I increase the number of mesh possible in Gambit?
Thanks
Old   July 16, 2008, 01:28
Default Re: Maximum no. of mesh fixed at 100k in Gambit?
David
memory size problem? or you may divide it into smaller regions to mesh separately
Old   July 16, 2008, 02:45
Peter
Hi David
I have 3GB of RAM and I dont think it's a limitation. I used to create 1-2 million mesh in Floworks.
I'll try your suggestion of dividing it into regions. Thanks
Old   July 16, 2008, 08:41
krishna
Go to Edit-> Defaults-> Trimesh-> Set Max face value as -1 to have no limit. Regards
Old   July 16, 2008, 08:50
krishna
Go to Edit-> Defaults-> Mesh->Trimesh-> Set Max face value as -1 to have no limit. Regards
Old   July 16, 2008, 21:44
YK
thanks krishna
maximum mesh expansion factor reg NVSD BABU CFX 2 November 20, 2008 04:46
maximum no. of nodes/cells which GAMBIT can handle Sanjay Jain FLUENT 0 April 2, 2008 10:54
Maximum Mesh Expansion Factor KK CFX 3 February 11, 2008 06:12
Maximum mesh expansion factor Daniel CFX 2 September 27, 2007 02:47
maximum size for tetra mesh arya CFX 0 July 5, 2007 10:59
