Problem Exporting to Tecplot
Old   July 15, 2008, 19:54
Default Problem Exporting to Tecplot
Craig
I have a problem exporting my entire 3D domain velocity field to Tecplot.
This is how I export from Fluent
file export tecplot filename (default-interior) x-velocity y-velocity z-velocity:
When I import into tecplot, my mesh is all screwed up (but the overall shape is there). I'm not able to triangulate, or create iso surfaces or stream traces.
However, if I import data from a plane in Fluent to Tecplot using the same procedure, it works perfectly.
How do I properly load my velocity field into tecplot?
Old   July 15, 2008, 20:05
Default Re: Problem Exporting to Tecplot
shehab abdelrahman
don't choose the default interior... or choose any thing from the list. the fluent then will export the whole boundaries and interioir as well. if you choose the interior only the fluent will screw it up. hope that might help you shehab
Old   July 16, 2008, 00:21
Craig
Thanks for advice. I imported the Fluent .cas and .dat file directly into Tecplot without using Fluent's export option. Unfortunately I got an "End-of-file error while skipping etc..."
This was resolved using this thread: http://www.tecplottalk.com/viewtopic...ghlight=fluent
Basically I had to re-write my .cas and .dat file as the original .cas and .dat was written while using the parallel solver (Fluent 6.3 - which has a minor bug, fixed in Fluent 6.4).
Exporting to Tecplot 360 Rogerio Fernandes Brito CFX 1 March 24, 2008 16:51
Exporting data to Tecplot 360 Genesis FLUENT 2 June 6, 2007 18:53
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 18, 2007 00:24
[TUI & Scheme] Exporting data under Tecplot Mickaël PERRIN FLUENT 0 November 19, 2001 09:21
Exporting Tecplot Files Sam Zakrzewski Tecplot 3 May 20, 1999 05:32
