reported mass flow differs from monitored mass flo |
July 14, 2008, 14:51 |
Hello
I am running a simple simulation which includes an inlet and an outlet. I am monitoring the mass flow rate on a graph as well as the residuals. Once the solution has converged the reported mass flow rate on report>surface integrals> inlet /outet etc is considerably higher than the values which were being plotted on the graph. Which one is correct and why is this happening? Thanks |
July 15, 2008, 03:46 |
Re: reported mass flow differs from monitored mass
Do you run solver and postprocessing both in double precision?
July 15, 2008, 05:13 |
Hello BastiL, I'm not sure what you mean when you say double precision?
Please explain? Thanks |
July 15, 2008, 09:19 |
surface integrals at inlet and outlet is correct if ur net mass flow rate is zero.. or very near to zero...
July 17, 2008, 13:44 |
When you start fluent ask for 2ddp (2 dimensions, double precision). If you used an old fluent version, writte
fluent 2ddp on the terminal, good luck |
Mass flow rate of the DPM mass sourse ?? | Rhinocao | FLUENT | 3 | January 21, 2011 13:10 |
volume fraction,mass fraction,bulk mass flow | nick | CFX | 0 | April 25, 2008 10:51 |
Mass flux and mass flow rate | us | Phoenics | 10 | March 31, 2006 03:06 |
volume fraction, Mass fraction and Bulk Mass flow | Dr.jones | CFX | 1 | January 25, 2006 05:32 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 09:45 |
