Rotating Disk
Old   July 13, 2008, 04:28
Default Rotating Disk
MohsenZendehbad
i should simulate a rotating disk in fluent, but i don't have any informtion about this issue. i just have the gambit output which is a meshed disk. can anyone help me how i should simulate the rotating disk and where i should enter the rpm of the disk?(i don't have access to fluent help)
Old   July 13, 2008, 05:19
Default Re: Rotating Disk
ROOZBEH
Hi; You should use a rotating reference frame. At the boundary condition, you should set a rotating domain at the FLUID zone. At this part, the rpm will be asked.
Anyway, I think that you can not peeform a successful simulation without FLUENT documentation. I strongly recommend you to try to provide this documentation.
Best regards, ROOZBEH
Old   July 13, 2008, 14:43
pour
Hi you could use axiysemetric swril model in fluent and set wall boundary condition with swril speed. sincerely Pourak
two liquids flow over rotating disk fadhil FLUENT 0 June 24, 2008 01:19
rotating disk zahid FLUENT 0 March 5, 2008 09:01
rotating disk David FLUENT 5 August 16, 2006 07:07
3-D Rotating Disk Ray FLUENT 0 January 10, 2002 12:28
liquid on a rotating disk? Cehuang FLUENT 0 March 10, 2001 07:23
