July 11, 2008, 02:57 |
Absolute pressure...pls help
I'm now doing the Fluent tutorial "Modeling unsteady compressible flow" and the Operating Conditions was set to be 0 Atm. It claims that any input pressure will be in terms of Abs. pressure. At the pressure inlet, the Gauge Total Pressure is set to be 0.9 atm. Does the 0.9 atm mean 0.9 bar (abs.)? Thanks for any help |
July 12, 2008, 13:46 |
Re: Absolute pressure...pls help
Hiya, Absolute Pressure = Operating pressure + Gauge Total Pressure. So, in your case, yes, 0.9 atm is 0.9 atm (abs.)
absolute negative pressure???? | john | Siemens | 6 | December 12, 2014 00:18 |
Negative Absolute Pressure | Doug | FLUENT | 4 | December 11, 2014 07:07 |
absolute and total pressure | novice | FLUENT | 2 | May 26, 2008 18:48 |
absolute pressure limit | Jianfeng Zou | FLUENT | 4 | October 25, 2007 02:56 |
absolute pressure limited | Boisson | FLUENT | 1 | December 9, 2001 13:21 |
