Kolmogorov turbulence time scale
Old   July 10, 2008, 14:16
Default Kolmogorov turbulence time scale
iko
I need to figure out the smallest (Kolmogorov) turbulence time scale of my simulation (unsteady, LES, segregated)
Thee Kolmogorov turbulence time scale is defined by ε and ν ;
So I need to find a way to compute the average rate of energy dissipation per unit mass (&epsilon, and kinematic viscosity of the fluid in fluent (&nu ?
Thanks in advance!
Old   July 11, 2008, 14:08
Default Re: Kolmogorov turbulence time scale
umesh javiya
May be u could use Custom Field Functions (in define menu) and define your variable... and visualise variable with contours.....
Old   July 15, 2008, 11:04
Ashwin
Try writing a UDF for it. Actually its not necessary to reduce to Kolmogorov scales in LES. To work on those small scales you must have Re^(9/4) points in free space. So you must first start with making the mesh very refined. You must have a lot of memory and computing power to work that
Kolmogorov scale .... LES LESer Main CFD Forum 6 July 3, 2015 07:01
Relation between turbulence modeling & time scale? M. Choi Main CFD Forum 0 September 1, 2005 19:29
CALCULATING KOLMOGOROV SCALE Coln Main CFD Forum 0 January 12, 2004 13:16
Kolmogorov scale T.Misawa Main CFD Forum 2 December 12, 2001 05:02
Kolmogorov scale of atmospheric BL J. Kim Main CFD Forum 0 December 8, 2000 12:45
