July 8, 2008, 10:46 |
pressure peak near wall at inlet
I have a problem when i simulate a polymer flow through a flow channel. The flow channel is a 90 degree elbow with a diameter of 20mm (2D-Cut = circle). When I simulate this flow and watch the contours of the pressure in the flow channel I get a very high pressure peak on the first few millimeters of the inlet but only near the wall. Why do I get this peak and how can I handle this problem? Thank you much. |
July 9, 2008, 05:46 |
Re: pressure peak near wall at inlet
velocity inlet vs pressure inlet | cheong | FLUENT | 6 | April 9, 2011 04:07 |
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet | gabriel | OpenFOAM Running, Solving & CFD | 16 | September 30, 2009 19:20 |
residual peak shot | mopen | CFX | 0 | August 11, 2007 00:04 |
Peak Clipping | Valdemir Ferreira | Main CFD Forum | 0 | September 30, 2004 09:02 |
Two-peak tracer curve | jim | CFX | 5 | November 2, 2003 08:05 |
