Problem about Fluent on Linux
Old   July 6, 2008, 10:26
Default Problem about Fluent on Linux
hbinma
Hi,I have a problem when I use Gambit and Fluent on CentOS Linux(x86-64). I have installed Gamit(Linux 32bit version) and Fluent(Linux 64bit version) on my computer(Intel Core Dual E4500). When I open Gamid and Fluent, it said that "Set the environment variable FLUENT_ARCH and try again". Then I search that on google, and someone said that it should set FLUENT_ARCH=lnx86 and others said that it should set FLUENT_ARCH=lnamd64. When I set FLUENT_ARCH=lnx86, Gamit can run, while Fluent can not run. When I set FLUENT_ARCH=lnamd64, Gamit can not run , while Fluent can run. Have some people can resolve this problem? Thank you!
Old   July 6, 2008, 10:28
Default Re: Problem about Fluent on Linux
hbinma
Sorry "Gamit" should be "Gambit".
Old   July 6, 2008, 10:59
BastiL
Why did you install 32Bit Gambit? There should be a 64Bit as well....
Otherwise you need to set Variable depending upon what program you want to run.
Regards.
Old   July 6, 2008, 11:49
hbinma
Thank you, BastiL. I don't have 64Bit Gambit. I have solved the problem by this mean: set FLUENT_ARCH=lnx86, so I can open Gambit by the command of "gambit"; then open Fluent by "fluent -alnamd64"
OpenGL problem in Fluent for Linux Jack FLUENT 4 January 23, 2007 07:32
GUI problem on linux Nuray FLUENT 0 July 27, 2006 03:16
CFX problem in LINUX 9 Alan CFX 14 August 9, 2005 10:24
some problem about fluent in linux ztdep FLUENT 1 July 15, 2005 22:03
some problem about g95 in linux ztdep Main CFD Forum 6 July 4, 2005 13:11
