Perforated Plate with Porous Media
Old   July 3, 2008, 15:16
Default Perforated Plate with Porous Media
giogio
I want to model a perforated plate with a Porous Media,how can I set coefficient? How can I decide the direction of porous media?
Thanks
Old   July 3, 2008, 15:28
Default Re: Perforated Plate with Porous Media
mettler
if your perforations in your plate are uniformly distributed in the plate, then you only need to model one hole. Sparrow wrote a paper about this way back. He was finding the heat transfer coefficient using the sublimation technique, but he was able to justify using one hole using the lampblack oil technique. I replicated the lampblack oil experiment and then verified that with Fluent. This all depends on how your perforations are arranged.
Old   July 3, 2008, 19:22
red lemon
plate+media=porous jump
Old   July 8, 2008, 09:36
umcad
hi, You may refer to Fuent manual regarding how to set the coefficients & flow directions.
Old   July 8, 2008, 16:07
mettler
if you are going to try to set the permeability with Fluent you need to have an actual lab model of your porous media. Those values are obtained from pressure drop v's velocity data.
Perforated plate Alex K. FLUENT 8 October 27, 2018 17:33
modeling perforated plate mokemex FLUENT 3 October 27, 2018 17:30
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 05:16
turbulence at a porous jump (perforated plate) andrew FLUENT 1 May 8, 2004 10:51
perforated plate as inlet? Shankar FLUENT 0 October 27, 2003 12:19
