operating pressure
Old   July 2, 2008, 23:02
Default operating pressure
mettler
I am trying to replicate my lab experiment that is flow over a heated flat plate at a high local reynolds number. In order to prevent pump cavitation I have to pressurize the loop to 25 PSI. When modeling this in Fluent I can set the operating pressure as such, but does that also modify the outlet pressure or do I need to set that as well from the default of zero guage?
thanks
Old   July 3, 2008, 05:47
Default Re: operating pressure
XD
The outlet pressure will certainly affected by the operating pressure definition. I think no caviation will appear in Flent if you don't turn the caviation model on.
Old   July 4, 2008, 04:52
red lemon
however absolute pressure will go below the saturation pressure with no cav model. Using the cav model you may also see negative absolute pressure in Fluent.
operating pressure and operating density phil FLUENT 5 November 7, 2017 18:02
gauge pressure and operating pressure? António Nery FLUENT 3 December 14, 2016 07:54
OPERATING PRESSURE manish FLUENT 6 February 25, 2011 05:40
Operating Pressure D Harvey FLUENT 0 June 4, 2004 14:12
Operating Pressure Nori FLUENT 1 April 7, 2004 12:29
