Meshing problem
Old   July 1, 2008, 10:31
Default Meshing problem
Tomas
When I try to mesh a volume with Hexcore, I've got the following message:
"edge intersects face ERROR: TG_Mesh_Domain failed with error code 1. There may exist excessive small aps between the volume boundary and hex-core boundary. Please try again by removing more boundary elements from hex-core by setting MESH. CARTESIAN. HEXCORE_OFFSET_LAYERS three(3) or a bigger value. "
I've got two questions:
How can I detect which edge and face are responsable for this bugg?
The default parameter is not listed in the current version (2.4.6) (Edit/Default MESH. CARTESIAN. ). Which parameter may I change in order to perform the meshing?
Thank you in advance,
Séverine Tomas
severine.tomas@cemagref.fr Tel +334 42 66 69 63
Meshing problem Sanjay Jain FLUENT 2 April 7, 2008 11:37
Meshing problem Sanjay Jain FLUENT 6 April 5, 2008 10:51
Meshing problem akr FLUENT 2 February 3, 2008 21:22
meshing problem danard CFX 3 March 2, 2003 20:17
Meshing problem John FLUENT 2 January 31, 2003 13:08
